urinal installation
I have a rough in for a integral trap urinal and was wondering the proper way to install this fixture?
Hi:clueless in kansas
If you aleardy have a rough in, install the plumming drain line to the height of the urinals drain outlet. Install the inlet water line twelve or more inches above the height of the urinals inlet water line.
Then install 2x4's between the wall studs where the urinals archor bolts go. <There is usually two at the top and one below.>
Coverup the wall allowing holes in the sheet rock or plywood for these lines.
Hoist the urinal up on the wall according to the instructional manuals directions and bolt the urinal into place.
Connect the inlet water flushing valve and parts according to the installation directions and test.
<I suggest you test using just plain water here only...hahaha>
If all goes well the first time, this job is complete. Have a beer or two. The beer will help with testing shortly afterwards too! hahaha
If the job does not go well...piss on it??? hahaha...:-)
Good Luck,
TomBartco
Good Luck,
TomBartco
