No water from shower
water will not flow from my shower. i have removed the shower head yet i can see no signs of a clogged pipe. what might the problem be? any suggestions?
Thanks for the insight! One question though. Is replacing a diverter valve something that I can do or does it require a plumber? It seems as though this must be located in the wall. Does this mean that I'll have to tear into the wall?
quote:<HR>Originally posted by OldGuy:
Sounds like you need to repair/replace your diverter valve.<HR>
Should be able to remove handle, and if you have or can get a valve socket (similar to a sparkplug socket)to fit your particular diverter valve, you should be able to pull it yourself. You can then rebuild it with new o-rings, washers and parts for that make/model, or replace it. Or call a plumber, who will have a socket that fits. Good Luck!
