clogged bathtub
Old 03-20-00, 10:13 AM
Unhappy
PLEASE HELP ME!!!!!
ABOUT 2 MONTHS AGO I ACCIDENTLY GOT SOME PAPER CAT LITTER DOWN MY BATHTUB DRAIN AND SINCE THEN I CAN'T GET IT FIX BECAUSE MY LAND LORD HAS CAST IRON PIPES AND NO DRAIN OUT SYSTEM ANND THE PLUMBERS I HAVE HIRED TOLD ME THE ONLY WAY TO FIX IT IS TO REPLACE THE PIPING AND MY LAND LORD REFUSES TO PAY 1200 DOLARS SO PLEASE IF YOU GOT ANY SUGGESTIONS (PLEASE HELP ME!!!!!) SONYA
Old 03-20-00, 01:48 PM
Post
Have you tried Liquid Plumber, Drano, or some other drain cleaner that is designed to dissolve clogs? Read the directions, and use accordingly until you get it cleared out.Good Luck!
Old 03-20-00, 11:48 PM
Post
Serenity,
Try the Drain cleaner method first as the OldGuy mentioned. Buy a good brand! If you have no luck that way, call your local roto rooter and tell them you have a (probably 1 1/2") cast iron drain that needs to be "scraped out!" He will use a special scraper tip that will actually scrape the inside of the pipe clean. Then run lots of hot water down the drain for a while to make sure you have washed all the debris out. Caution: there is a small possibility the "snake" can put a hole thru the pipe if its old. 2nd Caution: have a heart and make sure you tell the rotorooter guy that you used Draino or? in the drains. This way he will know to wear some good leather gloves to keep from getting his skin burned from the drain cleaning stuff!
Old 03-21-00, 06:44 PM
Cool
I think one of the better liquid drain openers is Pequa,I know the Depot carries it.Good luck
Dave
L.I.Handyman
HTML code is On
