Toliet repair !
Old 03-26-00, 02:39 PM
Question
The arm holding the float broke! I have a repair kit. Problem....can't get the old water supply out, it's tight, what direction should it be turned?
Old 03-26-00, 06:34 PM
Post
Righty tighty, Lefty Lucy, To tighten turn Clockwise. To loosen turn counter clockwise.
Old 03-26-00, 11:27 PM
Post
Clockwise should shut the water off, but it's happened more than once the washer in the shut off valve has deteriorated. In that case, you'll have to shut off the water to the house to fix both the toilet and it's shut off valve.
HTML code is On
