No Water From Pipes
Old 04-11-04, 04:31 PM
tbusby
Unhappy No Water From Pipes
I JUST MOVED INTO A OLD HOUSE THAT HAS BEEN SITTING FOR ABOUT AYEAR.WHEN WE HAD THE WATER TURNED ON RUSTY WATER STARTED TO SHOOT OUT OF FAUCETS THEN QUIT.THE ONLY RUNNING WATER WE HAVE IS COMING OUT OF THE TUB. DOES ANYONE HAVE ANY SUGESTONSWHAT I CAN DO.
Old 04-11-04, 04:33 PM
The nipple to the tub spout is probably galvanized, which needs replacing.
Remove spout, then nipple and/or nipples and 90, and replace with copper.
Old 04-11-04, 05:27 PM
Rainbird's Avatar
Sounds like when you turned on the water, crud in the water lines plugged up the aerators on your faucets. Remove the aerators by unscrewing (it's on the end of the faucet) and clean the screen. Do this on each faucet. Before you reinstall flush the lines.
Old 04-11-04, 05:31 PM
Damn.........I was way off target on that response. Sorry
I pick up keywords and run with it.
Tub spout, rust. sitting
Do you have galvanized piping in the home????
Old 04-11-04, 05:39 PM
Plumber2000's Avatar
tbusby
Please turn off caps lock.
And yes what type of pipes do you have in your house?
If galvanized, do think long and hard about replacing all of it.
HTML code is On
