shower faucets
Old 03-28-00, 12:15 PM
Guest
Question
when i turn the shower faucets off .. water continues to come out of the spout for apprx. 30 seconds , not full pressure, but first a small stream then down to dripping , then full shut-off. is this normal or am i having a problem? thanks
Old 03-28-00, 07:10 PM
Guest
Cool
You probably just need to replace the washers. Good luck! If you need help with that, just check back.
Old 03-28-00, 10:31 PM
Guest
Post
When you turn off the shower faucet, water comes out of WHICH spout?? The tub spout? If so, that is just the water draining out of the riser to the shower head. 30 seconds sounds a little excessive, but not terribly out of the ordinary.
