Toilet Repair
Old 04-01-00, 02:04 PM
Post
How do you get an old closet/flange out? When we tried to remove it, it broke off at the top. Is there a specialty tool? The new flange we bought screws in, but we don't think the old one does. Are they glued/cemented in?
Old 04-01-00, 08:04 PM
Cool
Old flange is probably glued in. You will have to hacksaw off pipe, and glue on a threaded female connection to screw the new flange into. Good Luck!
Old 04-01-00, 11:45 PM
Post
What kind of pipe is the flange connected to? In the past 30 years, ABS is most common. Before that no-hub cast iron; before that, lead and okum caulked joints in cast iron. Let us know that, then you will get a better answer.
HTML code is On
