Sewer smell in bathroom
Old 04-02-00, 08:10 PM
Question
For about 2 weeks now I have had this sewer smell coming from my 2nd bathroom. The smell comes and goes and is worse at different times. I don't have any moisture on the floor. I notice that the water level is lower then it was 2 weeks ago too. Any suggestions as to what this could be?
Old 04-03-00, 04:58 PM
Post
IS THE TOILET IN THAT BATHROOM LOOSE ?
CAN YOU MOVE IT SIDE TO SIDE, OR BACK AND FORTH ??
IF SO YOU ARE PROBOBLY GETTING SEWER GAS FROM UNDER THE TOILET..
Old 04-03-00, 05:42 PM
Post
quote:
The toilet doesn't move at all. I also checked to see if there was anything blocking the vents on the roof and it is clear. I am so confused as to why it stinks!
Old 04-04-00, 12:33 AM
Post
Does this bathroom get used on a regular basis? If not, run some water in the lavy, the tub and/or shower, and flush the toilet. What is probably happening is the the water is evaporating out of the traps.
HTML code is On
