Venting main line
Old 04-04-00, 09:49 AM
Post
I am replacing the old cast iron vent pipe that runs through the house and out the roof with 2" PVC. The old 2 1/2" cast iron pipe had several bends or 90 degree turns. My question is, can you have turns with a vent? Or should the pipe run straight up and out? If you can have turns, how many can I have...
Old 04-04-00, 10:52 PM
Post
You can have up to 4 90 degree bends (360 degrees total). Imagine yourself as a rain drop that enters the vent on the roof. Just make sure that there are no uphill sections in your path to the drain or waste line below.
HTML code is On
