Shower Arm Leak
Old 04-07-00, 10:31 PM
Guest
Question
In replacing the showerhead with a handheld, I noticed that the shower arm was leaking where it goes into the pipe in the wall.
Will replacing the washer fix this or am I in real trouble here?
Also, if the shower arm is tight, it is not in the proper position. Can anyone tell me how to remedy this also?
Thanks,
Lucy
Old 04-08-00, 06:03 PM
Guest
Cool
Just remove shower arm (threaded on both ends). Wrap both ends 2-3 turns clockwise with teflon tape, and reinstall. Should stop leaking. Good Luck!
