thermostat hot water heater
Old 04-08-00, 05:11 PM
Post
my water heater is on its lowest setting, however the water temperature is too high...could the thermostat be malfunctioning and causing the water to be heated hotter than the settings?
should i change the thermstat?
Old 04-08-00, 11:50 PM
Post
Sure sounds like a defective 'stat. I would replace the lower one first and see if that cures the problem, or just replace both and be done with it.
HTML code is On
