shower not working
Old 04-19-00, 03:01 PM
Guest
Unhappy
i have a three handle tub / shower.(one hot, one cold, one to go from tub water to shower water. When i turn from tub to shower, I get nothing. Help!
Old 04-19-00, 05:24 PM
Guest
Cool
Sounds like you need to repair/replace your diverter valve. Remove cap in handle with knife point. Remove handle screw and handle. If you can see and reach a hexagonal piece that is part of the valve body with a crescent wrench, do so. If you can't reach it, you will need to get a faucet socket wrench that will reach in and fit it (they come in different sizes, sometimes in a set). Remove valve, replace o-rings, washers, worn parts, or the whole valve. Just take it to a supply place and they can match it. Good Luck! Edit: Turn off the water first. LOL
[This message has been edited by OldGuy (edited April 19, 2000).]
