Clog master stuck in drain
Old 04-25-00, 08:35 AM
Post
I used a clog master/buster attached to a hose. I followed the instructions and slid
it down the drain pipe of my bathroom sink,
and now I can't get it to come back out.
I relieved the pressure, slid it in and out
all with no luck. It went in easy and now
it appears to be stuck. What can I do?
Old 04-25-00, 07:17 PM
Post
WHAT PORTION OF THE DRAIN IS IT STUCK ?
Old 04-25-00, 08:12 PM
Post
quote:
It's just past a bend under the floor. I'm not sure but I think it may be in a junction point, because when I move it back and forth
the toilet gurgles.
Old 04-26-00, 12:15 AM
Post
If you can't pull it back out, your choices are to: 1.) Open up the drain / waste line to retrieve it, or 2.) Cut the hose and use a snake to push it out of the drain system, into the sewer or septic tank.
HTML code is On
