LOW LOW Water Pressure!!!!
Old 04-29-00, 08:43 PM
Red face
Help! There is a SERIOUS problem with the water pressure in my condominium. For example, if the shower is on and someone turns on the water in the kitchen - water STOPS coming out of the shower!! If I flush the toilet in the bathroom, I have to wait until the tank has filled back up before using the shower. Oh, and if I'm doing laundry - forget it. No shower, no water in the kitchen sink, etc. Even when the shower is the only water running in the condo, it still seems to be just a trickle.
I have tried a new shower-head (the water-saver kind that increases pressure) but it just doesn't help. Is it too much to expect to be able to get a glass of water in the kitchen while someone is taking a shower??
What could be causing this to happen? It's actually been this way for awhile, but it is quite annoying.
Old 04-29-00, 09:32 PM
Post
Do you have a pressure reducing valve on the water service somewhere, if you do it could be no longer operating properly, you maight find this near the water meter.
PRV
HTML code is On
