hot water heater keeps tripping
Old 04-26-00, 07:17 PM
Guest
Red face
the red reset button on my water heating keeps popping out and must be reset. when i reset the water becomes so hot it's unbearble. is the element about to go out?
Old 04-26-00, 08:00 PM
Guest
Post
HAVE YOU CHECKED THE TEMP SETTING ON THE UPPER AND LOWER THERMOSTAT ? SHOULD BE 110/
115. YOU ARE MORE THAN LIKLEY OVERHEATING.
YOU MAY ALSO WANT TO CONSIDER REPLACING THE UPPER T-STAT.
[This message has been edited by GARPLUMCO (edited April 26, 2000).]
Old 04-26-00, 10:56 PM
Guest
Post
Replace both upper and lower stats at the same time
Would you replace just one spark plug in a cars engine for a tune up or would you replace them all?
Old 04-29-00, 11:20 PM
Guest
Post
IT IS NOT NECESSARY TO REPLACE BOTH. THE MAIN
CAUSE FOR THE T-STAT TO STOP WORKING IS WHEN SOMEONE UNQUALIFIED TAMPERS WITH IT AND SETS THE TEMP TO HIGH OR DOESNT MAKE SURE THE T-STAT IS FIRMLY TOUCHING THE TANK.
Old 04-30-00, 12:23 AM
Guest
Post
I have had to return on a few jobs cause of only replaceing the upper stat.
Lower Stats wear out just like the upper stat, don't you think so?
Stats
Old 04-30-00, 04:56 AM
Guest
Question
THE UPPER T-STAT IS FACTORY SEALED. WHEN I PURCHASED THE WATER HEATER 5 OR 6 YEARS AGO I SET THE LOWER T-STAT AS DIRECTED IN THE OWNERS MANUEL. THE WATER TEMP HAS BEEN FINE,
UP UNTIL 2 WEEKS AGO. DO YOU KNOW W THE APPROXIMATE COST OF REPLACING A T-STAT?
OR DO YOU THINK I SHOULD TRASH IT AND BUY A NEW ONE?
Old 04-30-00, 06:59 PM
Guest
Post
YES, THE T-STAT ITSELF IS INCLOSED,YOU SHOULDENT TRY TO TAKE IT APART, CAN YOU TELL
IF THE BACK SIDE OF IT IS FIRMLY AGAINST THE TANK ? IF YOU HAD A PLUMBER FIX IT I WOULD
GUESTIMATE APROX $120.00-$150.00, DEPENDING ON THE HOURLY RATE AND IF THE COMPANY FLAT RATES.
Old 05-01-00, 06:42 PM
Guest
Post
<HR>
Another fine example of a rip off, stats only cost 25 - 30 for the both of them, so if your paying 150.00 for a plumber you will be paying too much.
It onlt takes 15min to replaces the stats,
so you pay 120.00 for labor.
Too many money happy plumbers out there, call and get more then one estimate.
By The Code Plumber
