sprinklers
Old 04-05-00, 02:39 PM
Post
sprinklers run off of a well. it runs like a vacuum / when this is lost you lose the water and this is your prime. when it happens i fill the pipe to the pump with water and then run the pump, this starts the sprinklers and you regain your prime. thanks 4 trying to help. any suggestions?
Old 04-30-00, 02:09 PM
Post
If you are saying you are losing the prime on the pump what type of pump is it? If it is a Jet pump put a check valve in the suction line and you will not loose the prime any more.
Old 05-03-00, 05:35 PM
Post
Hummmm, sounds like plumbing to me...how about I send this over to them..see what they come up with...
HTML code is On
