Garbage disposal
Old 05-07-00, 07:27 AM
Unhappy
The garbage disposal just hums when turned on. The unit is only three years old. I have looked for anything stuck in the sink and found nothing. What do i do now?
Old 05-07-00, 08:19 PM
Post
THERE SHOULD BE AN AREA IN THE CENTER OF
THE DISPOSAL UNDERNEATH IT WHERE YOU CAN INSERT A HEX KEY, THIS WILL ENABLE YOU TOO
ROTATE THE MOTOR MANUALLY TO HOPEFULLY FREE IT UP, BE SURE THE SWITCH IS OFF WHEN YOU DO THIS.
Old 05-10-00, 06:35 PM
Talking
Thanks, that did the trick. Should i do any thing to maintain it so this doesn't happen again?
HTML code is On
