Hot Water Heater Anode Removal
Old 05-10-00, 02:23 PM
Post
Any hints on removing the hot water heater anode? I have tried a socket with a 1/2 inch breaker bar but can't get it loose. Heat, cold, penetrating oil? It sure is hard to hold onto the heater.
Old 05-10-00, 04:22 PM
Post
WHY DO YOU WANT TO REMOVE THE ANODE ??
Old 05-10-00, 04:37 PM
Post
quote:
He probably has a good reason, just help him your the moderator.
By The Code Plumber
Old 05-10-00, 06:12 PM
Cool
I'm not a plumber, and I've never removed a water heater anode, but I think that I would let it soak with penetrating oil, get someone to hold "back-up" on the heater, and carefully use a cheater pipe on your bar to see if you can't get enough leverage to break it loose and back it out. Good Luck!
Old 05-11-00, 11:46 PM
Thumbs up
quote:
By The Code Plumber
Isn't the tank protected until the anode corrodes away? Thus, by replacing the anode bar you may have the life expectancy of a new water heater.
Old 05-12-00, 09:04 AM
Post
[/B][/QUOTE]
Yes thats what the anorod is for.
Plumber2000
Old 05-12-00, 06:41 PM
Post
Sure, that's what the anode rod is for, however, if the water heater has gone through it's original anode rod it's probably time to replace the water heater, not just the anode rod. If the water heater is over 10 years old and has used up it's anode rod, it probably will develop a tank leak in the not so distant future.
Plumber2000
[/B][/QUOTE]
HTML code is On
