Installing new Kitchen faucet
Old 05-04-04, 06:29 PM
jdude
Question Installing new Kitchen faucet
I'm in middle of installation. My new Kitchen Faucet is installed using compression fittings..... The instructions "HIGHLY" recommend that the cooper water tubing must "flare or bead" to avoid blow out conditions.... How and what tool do you use to flare or bead a cooper water pipe?
Suggestions welcome quickly... No water in kitchen...
thanks
jdude
Old 05-05-04, 03:56 AM
Mike Swearingen's Avatar
You need what is called a flaring tool, available at most any hardware store. They aren't expensive. Tubing for a faucet is usually 3/8". The tool comes with various sizes on it.
I really don't know why it is mandatory to flare those water supply fittings with a compression fitting, because the compression fittings come with a ferrule (brass compression ring) that basically does the same thing (grips, seals and prevents blowouts).
Personally, I would use stainless steel flex supply lines between the cut-off valves and the fittings on the faucet lines. They have brass nuts on each end and built-in rubber seals and you don't even need to use pipe compound or teflon tape.
In any case,
Good Luck!
Mike
HTML code is On
