Toilet leak when flushed
Old 05-16-00, 09:06 AM
Angry
I replaced all the mechanical fixtures in two of my toilets, to stop the leaks. One went fine, the other has decided to leak through one of the bolts when I flush. It is an American Standard, and I have put on two different cone gaskets between the tank and bowl. I suspect that the gasket is not seating correctly, but have no idea why.
Mike
Old 05-16-00, 09:15 AM
Post
quote:
Mike
Hi Mike,
If the leak is through the bolt then it is at the bolt that the leak is taking place, try tightening it a little more, but be careful, if still leaks get a new tank to bowl bolt kit and install it.
Best Regards Plumber2000
www.atozplumbing.com
[This message has been edited by Plumber2000 (edited May 16, 2000).]
Old 05-16-00, 06:46 PM
Cool
When all else fails, try a little silocone caulk on both sides of the gasket. Good Luck!
Old 05-16-00, 08:23 PM
Post
quote:
For a positive seal on the bolts in this order.
Bolt, rubber washer, tank, rubber washer, round metal washer, nut. do for both sides, then set the tank, with nut and washer.
www.atozplumbing,com
HTML code is On
