mixer taps
Old 05-22-00, 08:58 AM
Guest
Unhappy
I do not know anything about plumbing but have a problem with the mixer tap on my shower. The hot and cold water mixes fine when coming out of the tap but when I switch it to the shower it does not mix and either goes entirely scalding hot, or you have to turn the hot down to a trickle at which point it loses pressure and becomes freezing. Is this a problem I can fix, and how?
Old 05-23-00, 02:38 PM
Guest
Post
quote:<HR>Originally posted by Interpickle:
I do not know anything about plumbing but have a problem with the mixer tap on my shower. The hot and cold water mixes fine when coming out of the tap but when I switch it to the shower it does not mix and either goes entirely scalding hot, or you have to turn the hot down to a trickle at which point it loses pressure and becomes freezing. Is this a problem I can fix, and how?<HR>
What type of valve is it? The brand?
Best Regards Plumber2000
www.atozplumbing.com
