Bathroom Sink Trap
Old 05-22-00, 08:47 AM
Guest
Post
My bath sink trap needs to be replaced at the main drain. The pvc is glued into the drain. Is there a way to separate the glued joint without cutting? If I do cut, will I be able to remove the old peice from the joint?
Old 05-23-00, 02:40 PM
Guest
Post
quote:<HR>Originally posted by gdunlop:
My bath sink trap needs to be replaced at the main drain. The pvc is glued into the drain. Is there a way to separate the glued joint without cutting? If I do cut, will I be able to remove the old peice from the joint? <HR>
I don't follow you here, at what point in the line, under the sink or under the house.
Best Regards Plumber2000
www.atozplumbing.com
