Washing Machine in basement w/ only drain fixture at ground level
Old 05-12-04, 11:51 AM
Mac34
Question Washing Machine in basement w/ only drain fixture at ground level
Does anyone know of any solutions for a washing machine in basement with no drain in basement...the person living here before has a flex hose running vertically about 5 feet to the drain pipe on main floor...the washer obviously does not drain properly...are there any solutions other than digging a hole in my basement for proper plumbing?
Old 05-12-04, 01:31 PM
Yes,they make a little pump pit that actually sits above ground.Its like a sump pump in a 5 gallon bucket with a sealed lid.You still need acsess to a drain line above head,or you can go out the wall and tie into your sewer line.
Old 05-12-04, 01:35 PM
OK I see you have a drain pipe so it would be no prob.I dont know the codes in your area but in some cases around here the inspectors will let you do a separate vent into the drain also.You will need to vent this.
Old 05-12-04, 04:58 PM
Mac34
Thumbs up thank you Zeroo!
i appreciate your help.
HTML code is On
