leeky kicthen drains after repair
Old 05-25-00, 01:15 PM
Guest
Question
after several attemps to fix the kicthen sink drain it still leeks someone please help
Old 05-25-00, 07:48 PM
Guest
Post
Are you dealing with brass, or plastic drain pipes? If plastic, then try loosing everything, realigning each joint to make sure it's straight, then start at the wall and the sink and tighten towards the center of the drain. The last joint you want to tighten is the waste arm where it exists the trap.
