broken shower head
Old 05-27-00, 07:03 PM
Question
any one have an idea on how to remove a piece of broken shower head that is in the female fitting that is recessed in the shower wall ?
Old 05-27-00, 08:19 PM
Lightbulb
Hi:[email protected]
Try an item called an easyout. Screw that into the female pipe as per the instructions, then back it out. This should remove the broken part.
You can ask at the hardware if there is an alternate tool or device for this type of job while your there also.
With some luck you may also be able to back it out with a small chisel or screwdriver but this can be tricky. I have been successful at this but it does take patience...hahaha
Good Luck
Old 05-27-00, 09:07 PM
Post
quote:
If the extractor does not work take a hacksaw blade and cut the broken piece inside the pipe, cut deep enough though the threads but not to deep, cut in about 4 places, then with a pick, you should be able to remove the broken threads out of the female adaptor in the wall.
Best Regards Plumber2000
www.atozplumbing.com
Old 05-27-00, 09:25 PM
Smile
it looks like i need some luck and a trip to the hardware store
thanks all
HTML code is On
