water heater supply system
Old 05-30-00, 01:31 PM
Post
WHERE CAN I FIND INFORMATION ON INSTALLING A LOOP SUPPLY SYSTEM IN THE HOT WATER LINE OF MY HOME. THE WATER HEATER WILL BE NEW AND I WILL REUSE SOME OF THE EXISTING COPPER WATER LINES. I AM VERY HANDY AND AM IN THE PROCESS OF REBUILDING A 1921 CRAFTWMAN STYLE HOUSE.
Old 05-30-00, 01:36 PM
Post
quote:
Are you taliking about a hot water return system?
Best Regards Plumber2000
www.atozplumbing.com
Old 05-30-00, 09:27 PM
Post
You're talking about a hot water recirculating system? Go to a supp;y house that sells the pump and they should be able to draw you a picture of exactly how to do it. Just need the pump, a couple of check valves, some pipe and the fittings. I also added a couple of ball valves in mine, one on each side of the pump, just to facilitate changing it if it ever becomes necessary.
HTML code is On
