well pump running
I have well water and the pump runs all the time. The pump is watered logged and I need to no how to drain the tank and repair the problem. Thank you if you can help.
If your pressure tank is waterlogged, then all you have to do is get a portable air tank and re-pressurize it, if the bladder is o.k. This will force the water out of the tank. There will be a fitting just like on a tire, and you can check pressure with a tire gauge. Pressure should be just above your cut-on pressure (probably 30-35 lbs psi). Good Luck!
