New Sewer
Old 05-31-00, 01:53 PM
Question
I an being required to go on city sewer and get rid of my septic system. My Q: is how much fall should I have on my new sewer line? I don't want to little so that it drains slow or to much so that it leaves solids behind.
Old 05-31-00, 03:25 PM
Post
quote:
Grade the pipe at 1/4" per foot and that should do just fine.
Best Regards Plumber2000
www.atozplumbing.com
Old 06-01-00, 01:52 PM
Talking
Thanks, I thought that was the fall rate but was not sure, and 10 search engines failed to lead me to the answer. Now if I can get the city to put in the lift station (they terminated the main 100ft from propline and I need 160FT to get to prop line so I'll be 9.5ft deep at the main 8ft in the ground) I'll be in good shape.
Old 06-01-00, 05:41 PM
Post
You can grade 4" to 1/8" per foot but only when authorized by the plumbing inspectors.
Old 11-21-01, 08:13 PM
need help patching hole in wooden door
i have a hole in a hallow wooden door, about 2 inches squared. can we use the same method as drywall patching? use drywall compound or something else.
HTML code is On
