Howling pipes
Old 06-11-00, 08:18 PM
Guest
Post
What causes pipes to howl, I can't tell if it is caused by the hot or cold water but if you are running the water and then turn it off the pipes in one of the bathrooms start howling for a few seconds and then stop.
Old 06-11-00, 08:25 PM
Guest
Post
quote:<HR>Originally posted by mlwright:
What causes pipes to howl, I can't tell if it is caused by the hot or cold water but if you are running the water and then turn it off the pipes in one of the bathrooms start howling for a few seconds and then stop.<HR>
Where do you here this sound and does this happen in more then one faucet.
Sometimes loose washers on the stems will cause sounds, you have to take the stems out and tighten or replace the stem washers.
Best Regards Plumber2000
www.atozplumbing.com
Old 06-12-00, 06:56 AM
Guest
Post
<HR>
The sounds seem to come from the bathtub. I just replaced the washers because we have the continual running water. One washer was completely gone. But even after replacing the washers we still have water running. the sounds were coming before I replaced the washers also.
Old 06-12-00, 07:00 AM
Guest
Post
The sound seems to come from the bathtub but you will hear the sound if you run water in a different facet, but it still sounds like it is the pipes in the bathroom.
Old 06-12-00, 10:08 AM
Guest
Post
The sound seems to come from the bathtub but you will hear the sound if you run water in a different facet, but it still sounds like it is the pipes in the bathroom.<HR>
It could be too much pressure, pressure in the pipes when moving can create a howling sound, do you have a pressure reducing valve, if so adjust it bt loosening up the the bottom nut and turning the scew on top clockwise. This is found 9 times out of 10 out infront of the water meter.
[This message has been edited by Plumber2000 (edited June 12, 2000).]
