Frozen washer hose
Old 06-19-00, 10:58 AM
Guest
Post
Any advice on how to remove a frozen washer hose from the shut off valve. I've tried penetrating lubricants without success.
Old 06-19-00, 11:25 AM
Guest
Post
Use a pair of channel locks to remove it. Use the same to install the new hose.
Old 06-19-00, 12:15 PM
Guest
Post
I did tried using channel locks but still couldn't get it loosened. Plus, the entire valve starts to turn during loosening. Any other suggestions?
Old 06-19-00, 03:06 PM
Guest
Post
<HR>
If will come off there, use some elbow grease, and it should remove from the bibb.
Best Regards Plumber2000
www.atozplumbing.com
Old 06-24-00, 09:19 PM
Guest
Post
Any advice on how to remove a frozen washer hose from the shut off valve. I've tried penetrating lubricants without success. <HR>
Cut though one side of the threaded ring on the female hose connector with a hacksaw or hacksaw blade and put a screwdriver blade into the cut to spread it apart. That should loosen it enough.
