Showerhead
Just installed a new tub, spout and showerhead. There is no water coming out of the showerhead. There is a thing you pull up on the spout to get the water to the shower. Did we forget to connect something?
Assuming everything is properly plumbed, it just may be that your showerhead is stopped up with debris. Take it off, and see if you have water coming out of shower pipe. If you do, then backflush and clean out the showerhead, and see if that doesn't solve the problem. If you don't have water coming out of the shower pipe after you remove the showerhead, then you need to re-do the plumbing. Good Luck!
