leaky bath tub and shower hot water faucets
Old 07-17-00, 11:37 AM
Guest
Post
what can be done to stop leaky bath tub hot water faucet as well as a leaky hot water faucet for the shower? Also, where does one turn off the hot water to addresss this problem? Terrible running water problem!
Aldean in Albany
Old 07-17-00, 03:29 PM
Guest
Post
Without knowing what kind of faucets you have it is impossible to tell you exactly how to rebuild them. You will have to cutoff the water, pull the faucet handles and replace the Washers, cartridges or o-rings inside the valves. Cut off the hot water at the hot water heater. If you don't have a cutoff valve on the cold side, you will have to go to your main water cutoff.
HTML code is On
