Leaking toilet tank
Leaking toilet tank
Where the water feeds into the toilet tank, on the bottom theres a white piece i assume is some sort of seal. In between that seal and the tank itself the thank leaks, so when i turn the water ;ine off it stops leaking even when theres water in the tank. any ideas?
Replace your toilet water supply line with a correct sized length stainless steel (braided) water supply.
Fluidmaster makes a good supply line and can be found on this site and at all big box stores.
