Icemaker Shutoff Valve
Old 07-01-04, 07:15 AM
Frislanda
I turned off the icemaker (with the shutoff valve) about six months because we didn't use the ice and it kept making random noises. Now I went to turn the icemaker on. It makes the ice, the same as always, except that the shutoff valve is dripping at a rather rapid pace. Is there anything I can do? Thanks.
Old 07-01-04, 07:46 AM
Mike Swearingen's Avatar
Received 1 Upvote on 1 Post
Must be a saddle valve on a copper line.
It shouldn't leak when opened all of the way, but if it does, it would be best to replace it with a (better) compression valve.
Good Luck!
Mike
Old 07-01-04, 07:53 AM
Frislanda
Can I do that or do I need to get a plumber?
Old 07-01-04, 08:59 AM
First, open the saddle valve all of the way to see if that stops the leaking.
If it doesn't, you can replace it with a compression fitting (no soldering, just two wrenches). You can shop for them wherever they sell plumbing parts. You will need to make up from a 1/2" (water supply line) reduced to 1/4" (ice maker line). The plumbing supply people should be able to find you what you need to do it, based on your particular set-up.
You may have to cut a short piece out of the supply line to get the fitting in (tubing cutter or hacksaw).
You don't need teflon tape or pipe compound on brass compression fittings...just a wrench and a back-up wrench to hold the fitting while you tighten it with the other.
Good Luck!
Mike
