Copper to PVC Vaste Drain
Old 07-06-04, 03:55 AM
CutterElk
Smile Copper to PVC Vaste Drain
Hello all. I hope all is well. Quick question. My grandparents called me over to look at their plumbing. I found they have a leak in the main waste drain from the upstairs toilet. What I would like to do is replace the leaking elbow's and 90's in the old copper pipe. I have two ways of doing this, which is better.
1. Can I use a PVC coupling to the current 3 inch copper pipe or
2. Do I use a rubber coupling to the New PVC to Copper piping.
Basically which will hold the joints better, a PVC coupling to Copper with PVC prime and adhesive or the Rubber coupling.
Thanks
Old 07-06-04, 01:00 PM
Mike Swearingen's Avatar
Received 1 Upvote on 1 Post
Use the neoprene rubber coupling (universally called a "Fernco", which actually is a brand name) and they're to code. Trying to glue a PVC coupling to copper wouldn't hold.
Good luck!
Mike
