Markings on Copper Pipe
Old 07-31-00, 12:05 PM
Guest
Angry
What do the different colours on the copper pipes indicate. What type of pipes should I be using when I install my new shower.
Thanks in advance for your help.
Old 07-31-00, 12:18 PM
Guest
Post
The color indicates the strength of the pipe. For residential construction, the cheapest is fine.
Old 07-31-00, 02:58 PM
Guest
Post
Type m copper is what I use alot of, but type l is thicker, and go with it if you can.
Best Regards Plumber2000
www.atozplumbing.com
Old 08-01-00, 10:18 AM
Guest
Post
<HR>
Thanks for response. If I used a 2 foot section of m (red) in the a shower line, is this dangerous in terms of durability. Would you rcommend I change it to I (blue)
Thanks for your advice
Old 08-01-00, 11:41 AM
Guest
Post
No, I wouldn't change it. There's probably a few hundred other feet of type M pipe in your house already. What's two feet more?
