toilet emptying after flush
i replaced the bathroom floor then put a new tiolet in and know when i flush it emptys fine and fills up fine but after 5 minutes the tiolet will slowly drain so the bowl is dry? help please!!!
Sounds like the maunline is on the verge of plugging up on you, if you have an outside cleanout, remove the cap and see if there is water in the pipe, if so clean this line out with a machine.
Best Regards Plumber2000
www.atozplumbing.com
