washing machine hookup + utility sink
I have a utility sink in which the washing machine empties into from a hose on top. I am trying to install a cabinet with a sink inside and I need information on how to make it so the washing machine empties directly into the drain line and not in the sink but also use the sink normally.
Received 1 Upvote
1 Post
You need to check with your Building Inspection Department to see what is allowed by local code.
A washing machine pump discharges a great deal of water, and usually should be drained into a 1.5"-2" drain pipe.
A sink drain assembly is 1.25" draining into 1.5".
You might be able to discharge the washer directly into a street T to the drain pipe after the sink drain assembly.
Good luck!
Mike
Good luck!
Mike
