Slow Bathtub Drain
Old 08-16-00, 09:22 AM
Guest
Question
My bathtub drain is getting slower and slower - the tub now fills to over half when I take a shower. I've tried to unclog it with a liquid drain cleaner - nope
Will plunging help? And if it does - do I have to do something with the overflow drain?
Thanks for your help.
Old 08-16-00, 09:27 AM
Guest
Post
Plunging MIGHT work, if you're really lucky. But the best way to clear the drain would be to put a small drain snake down through the overflow (after removing the stopper assy.) and snake out the trap. IF all else fails, call a drain cleaning co. to clear it for you.
Old 08-19-00, 01:10 PM
Guest
Post
Cax: If the tub stopper can be removed, use a 6" tweezer to remove hair & etc. Good luck
HTML code is On
