Switching Galv. water supply lines to copper
I want to replace my old galvanized water supply lines with copper and I checked on the copper pipe but there is 2 types (red and another type) Which is recommended for use in a Bathroom?
Received 1 Upvote
1 Post
You can use Type M copper pipe (thin wall) inside a residence.
You will need to use di-electric fittings between the galvanized and copper to prevent electrolysis corrosion.
Have you considered using PEX? It is flexible and much easier to install than copper, especially in a re-piping job, and what most people are going with now.
Good Luck!
Mike
Good Luck!
Mike
Thanks for the reply. I went to the home center and purchased Type "L" 1/2" copper pipe. I read that type "L" is the standard. About the transition fittings from galv to cpr I could only find Cast copper fittings is that the equivelant to or the same as the di-electric fittings you recommend? Thanks again.
