Clogged sink drain line
Old 08-26-00, 09:00 PM
Guest
Smile
Am able to get a 25' snake through my sink drain line with difficulty, but have done it several times. Problem is the line keeps immediately stopping up again, or almost so. Have noticed small lumps of white material coming out with the snake. Have also tried using a quart of sulfuric acid to open the line, but that didn't work either. Am totally puzzled on what my problem is. Will appreciate help.
Old 08-26-00, 09:26 PM
Guest
Post
Sounds like it needs a better machine to clean the line, one that have cutters on the end of it, sometimes a cable can pass through a blockage and not effect it at all, this is when you need to get out the big guns.
Call in a drain cleaning company to help you out on this.
Best Regards Plumber2000 www.atozplumbing.com
