running toilet
Old 09-02-00, 04:44 PM
Guest
Post
Toilet intermittantly runs continuously after flushing. It stops with manually lifting the float arm. It is a new toilet. What can I do to permanantly fix tis problem? There are 2 screws at the base of the float arm; do those need adjusting?
Thanks for any suggestions.
Old 09-02-00, 09:22 PM
Guest
Post
The float level is set too high. If you have a ball **** (big black ball on the end of a brass rod), bend the rod down slightly (use two hands on it!). If you have a fluidmaster vill valve, squeeze the pinch clip and slide the black float down a little.
