Toilet not emptying
I live in a condo with 2 bathrooms. One toilet will not flush out. The water comes in, but will not go down right away. Within a few minutes it has gone down, but paper, etc. is still in it. Is this a building problem or just my own individual problem? Everything else seems to drain OK. HELP.
A good plunger MAY cure the problem, but if it doesn't use a closet auger. Sounds as though something is blocking the S-trap in the toilet. Assuming that all of your other drains are flowing just fine, this is a clog of only your toilet. I really doubt that it is a bldg. problem.
quote:<HR>Originally posted by Pete:
Hi teddeybears:
Time to get out the plunger and plunge the toilet. There is a partial blockage in the line, probably right in the base of the toilet. A couple of good shots with the plunger should clear it right up!
Pete<HR>
Hi teddeybears:
Pete<HR>
