Drain Backing Up
My washer drains into a PVC pipe that is cemented through the floor. I think it is connected to an old shower drain about 2-3ft away. My problem is that when my washer drains it is now backing up through the shower drain. I have tried to clean the drain with vinager & baking soda but it is still backig up. What can I do to correct this? Thank You
You need to have this line cleaned out with a machine and blades, no other way to do this, I can rent a machine but it would be better to have it done by a drain cleaning company, lines are not the easy to clean out, if you never tried it before.
Best Regards Pumber2000
www.atozplumbing.com
[This message has been edited by Plumber2000 (edited September 09, 2000).]
