old leak, new wet floor
Hi there, In the spring of this year, one of my pipes under my bathroon sink, sprung a small leak. There was also some water damage to the floor in the neighbouring laundry room. The leak was fixed, the floor scheduled to be replaced. This past weekend I went into the laundry room and the floor was damp again. I could find no leaks anywhere. We have no basement, just a crawlspace, 2-3 feet clearance. I live on the coast of British Columbia, very wet area. However, the past week was very dry, with no humidity. Does anyone know if the moisture could be coming from somewhere else.
Thanks
Thanks
Check all drain and water line connections in that area, use a good flashlight.
Then fill up sinks and washer, let them drain and watch for leaks.
When washer goes into draining look it bottom of washer see if it might be the washer.
Best Regards Plumber2000
www.atozplumbing.com
[This message has been edited by Plumber2000 (edited September 25, 2000).]
