hOT WATER HEATER LEAK
Old 09-28-00, 12:31 PM
Guest
Post
My Gas Hot water heater is leaking water from what appears to be a pressure relief pipe (long pipe on side with release flange at top) What could be the cause and remedy for this?
Old 09-28-00, 01:50 PM
Guest
Post
Does this stop leaking after you run a faucet for any lenght of time?
If it makes it stop then your dealing with thermo-expansion, and a thermo-expansion tank will need to be installed.
If it don't stop, then try replacing the T&P valve and see if that fixes it.
Best Regards Plumber2000
www.atozplumbing.com
