waste water pipe
Old 10-04-00, 08:50 AM
Guest
Question
Is it a good idea to replace just a portion of leaking GALVANIZED waste water pipe with a plastic(PVC) pipe? What is the best way to connect the two materials? THANK YOU for the advise.
Old 10-04-00, 09:13 AM
Guest
Wink
Yes its fine to replace galvanized drain pipe with either pvc or abs plastic pipe.
The hardest part will be cutting the galvanized pipe. You can use a hacksaw if you dont mind the work, also you could rent a reciprocating saw (sawzall) to cut it or a large pipe cutter if you are lucky enough to have the room to turn it.
attach the new pipe with fernco style couplings, these are easy to use and have 2 hose clamps on them to tighten down. Get the style for "cast iron to plastic" you will need either a 5/16" socket wrench or nut driver to tighten this down.
Happy plumbing!
plumber john
