Air in toilet pipe
Had the water valve shut off
and someone flushed the toilet. Now there is air in the pipe. How do we get it out???
The air will bleed out, a few flushes will do the trick.
Best Regards Plumber2000
www.atozplumbing.com
Are you sure the noise is coming from air?Verypossibly the washer on your fixture shut off came loose when you turned it back on, This will make a steady rumbling sound.
Good luck, plumber john
[This message has been edited by jjohnson@nckcn.com (edited October 10, 2000).]
