Can't get element out of water heater
I can't get old element out of my water heater. It is a screw-in element, but no matter what, I can't get it to loosen. I tried the wrenches, pliers, and also purchased one of those "wrenches" for removing elements. Does anyone have any idea how I can loosen it up, so I can replace it?
Thanks.
Thanks.
Apply penetrating oil and let it soak in. Then hit your wrench repeatedly with a hammer to loosen. You can also try a good strong rap with the hammer straight inward as this sometimes breaks it loose too. Good luck and keep at it -- it may take a while.
Some can be a real pain to remove, I have in the past if the special socket don't work use a basin wrench and cresant wrench to get them removed.
Have the teeth for the basin wrench grab the outside edge of the element and hold real tight, use the cresant wrench for your leverage.
Best Regards Plumber2000
www.atozplumbing.com
[This message has been edited by Plumber2000 (edited October 18, 2000).]
If all else fails, go to an auto parts store and get a 1/2" drive, 1-1/2" socket. Use a 1/2" drive breaker bar and this socket to remove the old element.
And Plumber 2000, before you complain about the $20 spent on the socket, how much does it hurt when the basin wrench slips, with all that leverage from the cresent wrench being applied? OUCH!!!
I'm not one to complain, your option can work to, there is more then one way to attack a problem, Just a thought, on the socket, it to can slip, as you know there is not that much area that the scocket can grab hold of, and most sockets will be tapered on the front of them, this could lead to the socket slipping off the element, which can hurt just as bad.
Now I would take my chance on a basin wrenches teeth over the tapered socket end anyday, I have removed a few element with the basin wrench, yes one needs to be mechinically inclined and aware of what could happen if your not careful, being aware means knowing where the breaking point will be and knowing when too much is too much, for not knowing leads to injury.
But yes a socket can work.
