Can't remove garbage disposal mounting
Old 09-15-04, 12:23 PM
hokiejane
Here I go again trying to do it myself.
I'm trying to replace a Sinkguard SS270 garbage disposal with an Insinkerator 444. To do that, I need to replace the mounting assembly. The old assembly is plastic, and it appears as if the mounting ring should screw off, but I can't get it to budge. I've tried banging it with the screwdriver handle and immersing it in hot water...neither worked.
Can anyone help please? Here's a photo if it helps.
http://www.janegilbert.org/garbage.jpg
Thanks.
Jane
Old 09-15-04, 01:57 PM
Mike Swearingen's Avatar
Received 1 Upvote on 1 Post
It should unscrew off counter-clockwise, and you'll have to have someone hold the upper part.
Use a hammer and screwdriver to tap it around.
Good Luck!
Mike
Old 09-15-04, 03:32 PM
hokiejane
Oy.
I've been trying to tighten it.
I guess "lefty loosey" isn't always the case, eh?
Thanks much for the response. I'll go give it another shot in the right direction.
Jane
Old 09-15-04, 04:09 PM
majakdragon's Avatar
lefty loosy only applies if you are looking at the device from the end you are trying to unscrew. To this day, I still have to think when I am "under" something I am trying to unscrew. Laugh it off....happens to everyone.
